Rig Compatibility
The SIMRIG SR1, SR2, and SR3 motion systems can be mounted on many different rigs. We offer off-the-shelf solutions for aluminium extrusions in a variety of sizes. However, other types of rigs might also be compatible.
Contact us to inquire about your rig, or look it up in the list of known rigs at the end of this page.
These are things to consider regardless of rig construction:
  • The total weight shall not exceed 175 kg for SR1 (including driver, rig, and all accessories), 225 kg for SR2, and 250 kg for SR3
  • Less weight is better (higher mass means higher inertia)
  • The rig must be sturdy enough to handle the forces generated by the motion system
  • Maximum width is 620 mm unless EasyBrackets are used (see picture below)
../_images/rig-dimensions.png
Figure: Maximum rig width is 620 mm unless EasyBrackets are used.
Aluminium extrusion based rigs
We offer off-the-shelf solutions for aluminium extrusions of the following sizes. Most of these are extruded aluminium profiles with 8 mm slots.
Beyond the size, what matters is the profile’s faces. The EasyBrackets clamp to flat faces with accessible side slots, so a curved profile, or a smooth-sided one with slots on top only, takes the 20x20 option only. That holds at 40x80 mm and 1.5x4.5 in; a smooth-sided 40x120 or 40x160 mm profile fits neither option.
Profile
20x20 profiles
EasyBracket
20x60 mm
40x40 mm
40x80 mm
40x80 mm (convex)
40x80 mm (top-slot)
40x100 mm
40x120 mm
40x160 mm
40x160 mm (two-slot)
45x135 mm
1.5x3 in
1.5x4.5 in
1.5x4.5 in (top-slot)
1.5x6 in
40x100 mm (nlr)
40x160 mm (nlr)
Note
Other sizes are available on request at no extra cost. For example 45x45 mm, 45x95 mm, 30x60 mm, etc.
../_images/different-alu-profiles.jpg
Figure: Aluminium extrusions with off-the-shelf support.
Tube frame rigs and other types
Welded steel tube frames have no slots to bolt into and need a custom assessment. Contact us to inquire about your rig.
Foldable frames and kart-style low chassis are not suitable for the motion system.
Conversion kits
Some rigs have a ready-made answer: a conversion kit that adapts that rig to mount the motion system. Each fits its rig exactly, so no rig measurements are needed.
  • ClubSport GT conversion kit, for the Fanatec ClubSport GT. It includes three 80x40 extrusions that mount under the cockpit, EasyBrackets, and all the required hardware.
  • Trak Racer conversion kit, for the Trak Racer Alpine Racing TRX and TR8 Pro. Their tubular chassis offers no extrusion face for the generic mounts, so the kit brings pre-attached EasyBrackets and a set of aluminium profiles cut for it.
Mounting options
We offer two options for mounting the motion system to your rig:
  1. Set of four 20x20 profiles
  2. Set of four EasyBrackets
The EasyBrackets allows faster installation but the profiles are more cost effective and work for smaller rigs such as those with 40x40 profiles.
20x20 profiles
The SIMRIG SR2 in the picture below is mounted on a 40x80 aluminium extrusion rig using two 20x20x780 mm profiles. The profiles are attached to the rig using angle brackets, T-nuts, and bolts.
The profiles are 780 mm long; hence the rig width limitation of 620 mm. For a wider rig, the black profiles also come in an 880 mm cut — the Trak Racer S series is mounted this way.
Four 20x20 profiles and four plastic brackets are required to attach the SIMRIG motion system to an aluminum rig. These are included if the 20x20 mounting option is chosen.
The four 20x20 profiles are mounted in pairs. Two at the front of the rig and two at the back. Each pair holds two SIMRIG actuators.
The plastic brackets are designed to attach to a specific extrusion size. Different rigs are based on different extrusions and therefore require a matching bracket. Brackets for your chosen extrusion are included in the box.
See the user manual for more details on how to attach the profiles.
../_images/mount-20x20-profiles.png
Figure: Two 20x20x780 mm aluminium profiles are attached to the rig’s underside. The SIMRIG SR2 is attached to these profiles.
The profiles are available in both silver and black to match your rig.
20x20 profiles are the only option for 40x40 mm rigs. They are also a good option for less sturdy rigs as the 20x20 profiles form a base on which your rig is mounted.
EasyBrackets
The EasyBrackets were introduced in 2024 as a faster way to install the SIMRIG SR1, SR2, and SR3 motion systems. The EasyBrackets are a set of four aluminium consoles that come pre-attached to the actuators. They allow the actuators to bolt onto the sides of the rig.
See the user manual for more details on how to attach a motion system with EasyBrackets.
../_images/mount-easybrackets.png
Figure: A SIMRIG SR2 bolts directly onto the rig using the pre-attached EasyBrackets.
The EasyBrackets are black to match the actuators.
EasyBrackets are not compatible with 40x40 rigs.
Considerations
Choose 20x20 mm profiles:
  • Your rig is not yet assembled
  • Your rig is made of smaller profiles like 40x40 or 30x60
  • Your rig is at-most 620 mm wide
  • Estimated assembly time 4 hours
Choose the EasyBrackets:
  • Your rig is built and assembled
  • Your rig is wider than 620 mm
  • Estimated assembly time 1 hour
Known rigs
The rigs we know, and how each one mounts. This is the same list the shop’s configurator answers from. A rig that is not on it is not necessarily incompatible: contact us and we will find out.
Rig
Profile
Mounting
Notes
6Sigma Sim Racing 6S-80
40x80 mm
20x20 profiles + EasyBracket
6Sigma Sim Racing 6S-120
40x120 mm
6Sigma Sim Racing 6S-160
40x160 mm
6Sigma Sim Racing 6S-Slim
40x80 mm
80/20 Inc. DIY Racing Simulator (DIY2202)
1.5x3 in
20x20 profiles
Of the inch-profile sizes only 1.5x4.5 in is EasyBracket compatible; mount with 20x20 profiles.
Advanced SimRacing ASR 1
1.5x1.5 in
20x20 profiles
40x40-class profile; mount with 20x20 profiles.
Advanced SimRacing ASR 3
1.5x3 in
20x20 profiles
Advanced SimRacing ASR 4 Flat Face
20x20 profiles
Marketing confirms the 20x20 set underneath this face. EasyBrackets have no side slot to clamp, so it has a profile of its own rather than the generic 1.5x4.5 in, which offers them.
Advanced SimRacing ASR 4 Open Face
1.5x4.5 in
The two faces were one row until marketing separated them; they differ in what fits, so they are two rigs to anyone choosing a mount.
Advanced SimRacing ASR 6
1.5x6 in
20x20 profiles
Advanced SimRacing ASR F-Aero
1.5x3 in
20x20 profiles
Formula-style cockpit sharing the ASR 3 base profile; mount with 20x20 profiles.
Advanced SimRacing ASR F-Pro
1.5x6 in
20x20 profiles
Advanced SimRacing ASR K
Aluminium profile
20x20 profiles
Cross-section dimensions are not published by the manufacturer, but marketing confirms the 20x20 set; EasyBrackets are not compatible.
Advanced SimRacing ASR Pro
1.5x6 in
20x20 profiles
Apevie Simulator SP Cockpit
40x80 mm
20x20 profiles
Marketing confirms the 20x20 set only; EasyBrackets are not compatible, which the generic 40x80 profile would offer.
Asetek Initium 2-in-1
Steel frame
Not compatible
Welded steel frame; requires a custom assessment.
Conspit FC-Lite / FC-Pro
Special construction
Not compatible
Monocoque construction; requires a custom assessment.
Conspit GT-S
Steel frame
Not compatible
Foldable steel frame; not suitable for the motion system.
Extreme Simracing AX80
40x80 mm
Also sold as Apex Sim Racing AX80.
Extreme Simracing AX160
40x160 mm
Marketing confirms both options fit. Also sold as Apex Sim Racing AX160. The profile has no shop dimension of its own, so the choice is still made by hand.
Extreme Simracing Chassis 3.0
Steel frame
Not compatible
Steel frame without T-slots; requires a custom assessment.
Extreme Simracing Chassis 4.0
Steel frame
Not compatible
Proprietary construction
Supported through the ClubSport GT conversion kit rather than the generic 20x20 or EasyBracket options: three 80x40 extrusions under the cockpit, EasyBrackets, and all the required hardware. The kit fits exactly, so no rig measurements are needed.
Fanatec CSL Cockpit
Hybrid construction
Not compatible
Tube chassis without T-slots; requires a custom assessment. Current revision is V1.5.
Fanatec RennSport Cockpit V2
Steel frame
Not compatible
Steel chassis; requires a custom assessment.
GT Omega ART
Steel frame
Not compatible
Steel frame without T-slots; the two-piece construction also makes it a poor actuator platform. Requires a custom assessment.
GT Omega HYBRID
40x80 mm
GT Omega PRIME
40x160 mm
GT Omega PRIME Lite
40x80 mm
Uses a 40x80 mm base, unlike the full-size PRIME’s 40x160 mm.
GT Omega PRIME Lite-R
Aluminium profile
20x20 profiles
Marketing confirms the 20x20 set; EasyBrackets are not compatible. The cross-section is still unpublished, so the rig carries no shop dimension.
GT Omega TITAN
Steel frame
Not compatible
Steel tube frame; requires a custom assessment.
GTR Simulator GTA / GTA Pro / GTS-F
Steel frame
Not compatible
JCL SimRacing To Be Faster
40x80 mm
20x20 profiles
Minneer 4080 Racing Sim Cockpit
40x80 mm
Next Level Racing F-GT
Steel frame
Not compatible
Steel frame; requires a custom assessment.
Next Level Racing F-GT Elite
40x100 mm (nlr)
Marketing confirms both options fit this extrusion, EasyBracket included, which the generic 40x100 does not offer — hence a profile of its own. The attention flag stays until the fitment is checked on a rig in the room.
Next Level Racing F-GT Elite 160
40x160 mm (nlr)
Confirmed with EasyBrackets: the thick-walled profile has the flat surfaces and side slots they clamp to, and marketing confirms the 20x20 set underneath as well. Its own profile because the extrusion is proprietary, not a generic 40x160.
Next Level Racing F-GT Elite Lite
40x80 mm
Standard T-slot 4080 profile, unlike the proprietary 40x100 F-GT Elite. Sold as Front & Side Mount and Wheelplate editions.
Next Level Racing F-GT Pro
Steel frame
Not compatible
Next Level Racing Go Kart Plus
Steel frame
Not compatible
Kart-style low chassis; not suitable for the motion system.
Next Level Racing GTELITE
40x80 mm
Standard T-slot 4080 profile (unlike the smooth-sided F-GT Elite). Sold as Front & Side Mount and Wheelplate editions.
Next Level Racing GTELITE Lite
40x80 mm
Sold as Front & Side Mount and Wheel Plate editions.
Next Level Racing GTRacer 2.0
Steel frame
Not compatible
Next Level Racing GTtrack
Steel frame
Not compatible
Next Level Racing RC E
Steel frame
Not compatible
Next Level Racing Victory
Steel frame
Not compatible
OpenWheeler (SimFab) GEN3
Steel frame
Not compatible
Welded steel frame without T-slots; requires a custom assessment.
Oplite GT3 Superfast
Steel frame
Not compatible
Steel tube frame; requires a custom assessment. Current revision is V2.
Oplite GTR S8 Infinity
Steel frame
Not compatible
Steel tube frame; requires a custom assessment. Sold as Infinity, Infinity Force, White, and Elite variants plus a chassis-only version.
Oplite NitroKart
Steel frame
Not compatible
Oplite R8 Fury
40x80 mm (convex)
20x20 profiles
Convex (curved-face) 40x80 profile with its own 20x20 bracket; the mixed aluminium/steel-tube construction is not compatible with EasyBrackets.
Playseat Evolution
Steel frame
Not compatible
Playseat Evolution PRO
Steel frame
Not compatible
Playseat Formula
Steel frame
Not compatible
Playseat Formula Instinct
Steel frame
Not compatible
Playseat Formula Intelligence
Steel frame
Not compatible
Playseat Sensation PRO
Steel frame
Not compatible
Playseat Trophy
Steel frame
Not compatible
RECART GTR Evo / GTR S Evo
40x80 mm
Not compatible
Not compatible: there is nowhere on this chassis for the top brackets to sit. Marketing checked it on the rig.
RECART GTRx / GTRx Evo
40x120 mm
Not compatible
RECART REVO
40x120 mm
Ricmotech AP-Xtreme (APX-500 Lite / 1000 / 2000 / 3000)
Hybrid construction
Contact us
Slot access varies by model; contact us to confirm fitment.
RigMetal Basic / Plus
40x80 mm
RigMetal Flagship
40x160 mm
RSeat A1 PRO GT / Formula
40x160 mm
RSeat N1
40x160 mm
Sabelt Sim Racing S97 / P97 / X97
40x120 mm
Marketing confirms both options fit the Zero-X profile. It has no shop dimension of its own, so the choice is made by hand.
Sabelt Sim Racing S99 EVO I / P99 EVO I / X99 EVO I
EasyBracket
Two-slot 40x160 Zero-X base profile: supported with EasyBrackets only, not the 20x20 option.
Sabelt Sim Racing SIM LITE
80x80 mm
Marketing confirms both options fit. The 80x80 mm section is outside the off-the-shelf range, so the rig carries no shop dimension.
Sim Motion 80mm Aluminum Extrusion Chassis
40x80 mm
Sim-Lab GT1 Evo
40x80 mm
Sim-Lab GT1 Pro
40x80 mm
Sim-Lab Mercedes-AMG PETRONAS Formula One Team
Aluminium profile
Not compatible
Not compatible: the rear actuators sit too far forward on this chassis. Marketing checked it on the rig.
Sim-Lab P1-X
40x160 mm
The original P1-X, on standard quad-slot 40x160 profiles. Its successor, the P1X Pro, has a two-slot base that takes EasyBrackets only — check which one you have.
Sim-Lab P1X Pro
EasyBracket
Two-slot 40x160 base profile with pre-drilled sandwich plates: supported with EasyBrackets only, not the 20x20 option.
Sim-Lab P1X Ultimate
40x160 mm
Sim-Lab X1-Pro
40x120 mm
Simetik K1 / K2-R / K3 / X2
Steel frame
Not compatible
Simforge Apex
40x80 mm
SimXPro FR DD Formula
40x80 mm
SimXPro GT (Starter)
40x40 mm
20x20 profiles
40x40 mm is too narrow for EasyBrackets; mount with 20x20 profiles.
SimXPro GT-PRO
40x160 mm
SimXPro GT-RS
40x80 mm
SimXPro R80
40x80 mm
SimXPro X80
40x80 mm
SimXPro XFR Formula
EasyBracket
A wide rig: marketing confirms EasyBrackets only, so it takes the two-slot profile rather than the generic 40x160, which would offer the 20x20 set the width does not allow.
SimXPro XT120
40x120 mm
SimXPro XT160
40x160 mm
Sparco Evolve
Steel frame
Not compatible
Tubular chassis
A tubular chassis: the conversion kit brings its own profiles and EasyBrackets, so the generic mounts are not offered.
Trak Racer RS6
Steel frame
Not compatible
Shared a row with the TR8 Pro until marketing separated them, and the two do not mount alike: the conversion kit is cut for the TR8 Pro, and nothing we sell fits this frame.
Trak Racer TR5
Steel frame
Not compatible
Trak Racer TR8 Pro
Tubular chassis
A tubular chassis: the conversion kit brings its own profiles and EasyBrackets, so the steel frame needs no assessment of its own.
Trak Racer TR40
40x40 mm
20x20 profiles
40x40 mm base is too narrow for EasyBrackets; mount with 20x20 profiles.
Trak Racer TR80
40x80 mm
All variants (TR80, TR80 LITE, TR80S, Mk5) share the same base profile.
Trak Racer TR80S
40x80, 40x120 or 40x160 mm
Black 20x20x880 aluminium profiles
The S rigs are wider than the 620 mm the standard 20x20 set reaches, so the under-rig option is the 880 mm cut.
Trak Racer TR120
40x120 mm
Trak Racer TR120S
Trak Racer TR160
40x160 mm
Marketing confirms both options on the current revision. Earlier TR160 versions have an offset fixing pattern that EasyBrackets cannot use, so the flag stays until the customer’s version is known.
Trak Racer TR160S
The S rigs are wider than the 620 mm the standard 20x20 set reaches, so the under-rig option is the 880 mm cut. Unlike the earlier TR160, the S fixing pattern takes EasyBrackets.
Treq Ace
40x160 mm
Treq CXX
40x120 mm
Treq Formula Rig
40x80 mm
Treq One
40x80 mm
Treq Rookie
40x80 mm
Vesaro Vesaro I
Steel frame
Not compatible
Welded steel frame; requires a custom assessment. Sold in Stage 1-7 packages and a Formula configuration.
Virtual Racing Hub VRH F-Pro 2.0
Aluminium profile
20x20 profiles
Virtual Racing Hub VRH LITE
Steel frame
Not compatible
Virtual Racing Hub VRH LITE 2.0
Steel frame
Not compatible
Virtual Racing Hub VRH TX
Steel frame
Not compatible
Virtual Racing Hub VRH-1 Pro / 1LR / Formula
40x80 mm
Virtual Racing Hub VRH-1LE
40x80 mm (convex)
20x20 profiles
Convex (curved-face) 40x80 profile with its own 20x20 bracket. EasyBrackets clamp to flat profile faces and do not fit the curved shape.
Virtual Racing Hub VRH-2.0
40x80 mm (top-slot)
20x20 profiles
Smooth-sided profile with no side slots: EasyBrackets have nothing to clamp to, and the 40x80 size takes the 20x20 option.
Volair Sim Universal Cockpit (VS-01)
Steel frame
Not compatible
